주요 콘텐츠로 건너뛰기
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450 질문 전체 보기
Why does my iPad keep on showing the dead red battery loop?
Ive had this iPad Air 2 for about 2 years. Today I woke up to turn on my iPad but instead it showed a dead red battery icon, even though it was plugged in all night. Then I kept on holding/pressing the power button and finally it went to the Apple Reboot screen, only after it took me to the passcode screen it stayed on it for about 10 seconds and then shut down again. Ive been trying to fix it but I don’t know what to do as it only stays on for 5-10 seconds, and also the battery icon says 100%.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Are you using an original (or MFi certified) Apple charger and cable?
When troubleshooting battery/charging issues, I would do the following (in order). Some of these steps are much easier to do on a phone than a tablet but complete what you can and report back:
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. Change the battery. The battery is the weakest link in the entire device and certainly for charger related issues. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement(unfortunately, this will only work if you can boot the device).
  4. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging.
  5. You may have a logic board issue. There is an IC (commonly referred to as Tristar) responsible for communicating with the charging device and uncertified chargers can damage it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Would changing the battery cause any data on my iPad to be lost?
댓글 달기
귀하의 답변을 추가하세요
Blazing Coder 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 19
전체 시간: 756
