주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
293 질문 전체 보기
To Fusion or Not - after transplanting my MacBook Air 512GB SSD
Hi,
After much toying around I finally transplanted successfully my old MacBook Air 2015 512GB SSD into my 27” iMac 2017. While at it I also decided to drop in a Crucial MX500 1TB.
Will a Fusion setup be faster than my old Mac 512GB SSD solo?
I take it a Fusion setup will probably not be as stable. But I backup regularly.
I’m very happy with the speed of the iMac post-transplant.
Thank you for any advice.
- Carl
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You don’t gain any benefit with a Fusion Drive setup with two SSD’s. In fact you loose performance! The best setup is a dual drive setup.
  • Use the blade SSD as your boot drive as well as hosting your Apps and nothing else!
  • Use your SATA drive as your data drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Thank you Dan.
What would be the best way to proceed in terms of executing your suggestion?
Thanks again.
-Carl
Required steps:
● Backup your data!
How to split up a Fusion Drive
● Setup the blade SSD as your boot & app drive - Format & install OS - APFS
https://www.macworld.com/article/3284378...
◆ Leave the rest of the drive empty! Ideally 1/4 for a 512 GB/1 TB
● Setup the SATA drive as your data drive - Format - HFS+ if HDD, APFS if SSD
Hi Dan.
Big thanks.
I've done all that. Wish I could show you a screen shot.
I should have asked. How do I create Symbolic Links from "Macintosh HD" (which is the Apple blade to "Macintosh HD2" which is the storage drive.
I have something like 150GB in my Documents folder and another 100GB in Pictures which all really should be living on the HD2.
I thought a symbolic link would be the best way to do it?
I searched for creating symbolic links but strangely they weren't that helpful. I did get a good setup going using the following only to find problems with Downloading in Safari and Airdrop. So I gave up and thought I'd ask you. I suspect it's better to not remove the folder with the 'rm' command.
*All my data is still living on the portable external drives.
Admins-iMac:~ Carl$ pwd
/Users/Carl
Admins-iMac:~ Carl$ sudo rm -rf ./Downloads/
Password:
Admins-iMac:~ Carl$ ln -s /Volumes/HD2/Downloads Downloads
Admins-iMac:~ Carl$ ls -al
Simple put what are you trying to do? Give me an example or two.
Review this https://www.lifewire.com/aliases-symboli...
댓글 달기
귀하의 답변을 추가하세요
Carl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 66
