주요 콘텐츠로 건너뛰기
다양한 제조업체의 Windows 태블릿 수리 안내서 및 분해도.
1125 질문 전체 보기
Password change on RCA Windows 10 tablet
How do I change the password on my RCA Windows 10 tablet? It keeps coming up with the message that it requires a removable media, such as a USB flash drive. Please connect flash drive and try again. I have tried and it still doesn't work.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
You can use another account on the computer to reset your password.
If there are no Administrator accounts on the system, you can boot to Safe Mode to access the Built-in Administrator account. From this fail-safe account, you can force-reset your account's password.
  1. Press Windows icon+I to display the Settings charm menu.
  2. Click the Power Options icon, then hold down the Shift Key while you click the Restart option. Keep holding shift until the screen says it is restarting.
  3. On the first screen that appears, select Troubleshoot, then select Advanced Options. Finally pick Startup Settings and click the Restart Button.
  4. On the next screen, press the Number 4 Key to choose Safe Mode.
Now that you are in safe mode, you can use the built-in backup Administrator account to perform you necessary recovery. The built in Administrator account should not be used for any other purpose, or it won't be available in situations like this when you need it.
  1. At the login screen, click the Arrow Icon and select the Administrator account.
  2. After Safe Mode starts, press Windows icon +W and open Control Panel / User Accounts.
  3. Select Manage another account and select the account you wish to change to an Administrator account. You can also use the Change Password option here to reset the other account's password.
When you're done, restart the computer normally.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joan Wallace 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,250
