주요 콘텐츠로 건너뛰기
Presented at the April 2003 New York International Auto Show, for the 2004 US model year, the Prius was completely redesigned. It became a mid-size liftback, sized between the Corolla and the Camry, with redistributed mechanical and interior space significantly increasing rear-seat legroom and luggage room.
Overall systems maintenance on ‘07 Prius
After how many miles should ‘07 Prius be checked?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
I’d say a used/older car should be checked out by your regular mechanic at least once a year. The reason is that oil should be changed each year (even if the car isn’t used much) for the health of the car. You can use that opportunity to ask the shop to do a check on the car for safety. No need to go to the Toyota dealer though, go to an independent shop that can scan codes properly and has worked on lots of Priuses. For that oil change visit, I’d recommend going to the same shop, not asking at a local ‘Jiffy Lube’/while-you-wait oil change place or a large chain, as those companies will probably tell you you need things that you don’t need.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@chrissm you did not tell us how many miles you have on your Prius. Attached is the Maintenance Manual which tells you what needs to get checked according to the miles that it shows. Toyota Prius Maintenance Guide
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Christine maciel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 317
