주요 콘텐츠로 건너뛰기
The Acer Extensa 4630z is a laptop computer introduced by Acer in 2008. The Acer Extensa series is a line of Acer laptops designed for business and office users.
4 질문 전체 보기
Why is the display not working after I reinstalled the RAM?
I removed and reinstalled the RAM and HDD and powered my laptop and it ceases to display anything. As a matter of fact it was working properly before but was crashing during Windows Xp loading with BSOD, Now the laptop powers on but no display whatsoever.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
@huracanevo are there multiple memory module installed?
test with one stick at a time
I only have single RAM but two DIMM
slots
댓글 달기
답변 2개
선택된 답변
It is seem to be only some boot hardware failure. Do you get any system beep sound when you power on laptop. Do one thing. Only install RAM in same slot where it was working before. Do not install HDD. Now power on laptop. Also inform any LED on display turn on or now.
I think ram is not properly installed or hdd is not properly fixed. Inform us what is system sound or beep sound when turn on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
There are no beeping hardware internally installed .... there are LEDs indicating HDD ........ I will give it a try
Display should work no matter HDD is installed or not ,right Its just the RAM that display is affected
Did it and no sign of display working..........But the first time I press power button it powers up ...shuts down for a while and then powers up again......What is the cause?
댓글 달기
가장 유용한 답변
The ram may not be seated in fully or dust is inside the ram slot. Make sure they are seated in well.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
No I did it multiple times but the results are same
Hi @huracanevo ,
You didn't leave the battery in when you removed / replaced the RAM and HDD did you?
Try a power reset,
remove battery (and charger if inserted) press and hold Power button for 20-30 seconds then release.
Insert charger and switch on charger (leave battery out)
Assuming RAM at least is installed, turn on laptop and check if display works.
I actually went through Youtube videos that said static could be the cause of display not working......I did that multiple times as well ...no luck
댓글 달기
귀하의 답변을 추가하세요
Namaste Holiday 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 313
