2006 accord v6 auto trans. vsa light stays on. how do I fix this?
My VSA LIGHT STAYS ON STEADY, IT'S BEEN 2 DAYS G OING ON. WHAT DOES THIS MEAN? HOW DO I, FIX THIS PROBLEM? WHAT DOES VSA STAND FOR?
좋은 질문 입니까?
좋은 질문 입니까?
Hi @mchwalowski ,
VSA denotes Vehicle Stability Assist.
To quote the owner manual:
VSA helps to stabilize the vehicle during cornering if the vehicle turns more or less than desired. It also assists you in maintaining traction while accelerating on loose or slippery road surfaces. It does this by regulating the engine’s output, and by selectively applying the brakes.
With the car parked and the engine running try pressing the VSA Off switch to see if you can make the light go off and come on again.
Here’s an image taken from the owner manual (p.183) showing the location of the VSA Off switch on the dashboard.
(click on image to enlarge fro better viewing)
If operating / releasing the switch doesn’t help then you may have to take the car to a Honda dealer to get the VSA system checked out.
해당 답변은 도움이 되었습니까?
Is it something that has to be replaced immediately
@Candy Flesch
If you're driving with the compact spare tyre on for any reason this may be why the VSA light is on. Press the VSA switch on the dashboard to turn off the VSA system until you get the regular tyre repaired
Depending on your location it might be advisable to get the VSA system checked out sooner rather than later.
If you live in the northern hemisphere with winter coming on, the VSA system improves traction and handling stability in wet or icy conditions therefore the vehicle is safer to drive in these conditions.
The car's braking system is not affected when there is a problem with the VSA it's just that the handling when having to use the brakes is not as good as when the VSA is working OK.
24 시간 전: 0
7일 전: 2
30일 전: 35
전체 시간: 3,415
