My phone can be turned on but there is no software
my phone software is damaged due to usage of bluetooth so it can be turned on but there is no software for it to move forward how can i fix it?
좋은 질문 입니까?
좋은 질문 입니까?
Have you tried to format your phone yet? Connect the phone to your computer, then format. Or you could try to remove your MMC and type *#7370# n will ask u the security code.You need to type in your code, if you have never changed it, it should be 12345. Always make sure that you do have a full battery so that your format does not get disrupted. It also seems that *#7780# might work too. Just remember that any of these step willdelete the information that you might have on the phone. The other thing you could try is to re-flash your phone. There is a video on youtube.com that will help you with that. You can also try to re-flash your phone, and the firmware is available right here. Good Luck and let us know how it is going.
해당 답변은 도움이 되었습니까?
Thanks For This Good Answer. I am Already Found This Site On The Google Search Engine.
해당 답변은 도움이 되었습니까?
Sorry I did not see any solution to the original problem on your link. You wouldn't be spamming here, would you?
i thought that..name=same as site, but it was about similar stuff so...
That's why I left it alone as well, but will continue to monitor :-)
I wouldn't really call this spam, but it would be very helpful if you provided a link to the particular solution that the user needs, rather than a general link to the site.
his only other answer was to this site for an irrelevant question
sweftor hank my kokia 5130 mobaile no work
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,952
댓글 1개
what your phone shows after start? is that rebooting on nokia ? there is only one way to use is to flash it to latest version of Rm-495 is of Nokia 5130 phone.
SIMRAN 의
