주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
iPhone 7 - Taptic Engine (Very quiet) - Replaced Engine, Port ErghhH!
Hi,
I have an iPhone 7 here with a logic board fault, no surprise there. What may surprise you is that the problem is the taptic engine, when you press the home button or hold down an app for 3d touch, the phone does what it should on screen but only the tiniest vibration comes out of the engine, audible only if you put the phone right to your ear, you dont feel anything. The phone has just had a Tri-Star repair at a reputable source, the charging port and engine have been replaced 3 times in order to rectify the issue with no luck!
No water damage at all.
Anyone have any ideas what it could be?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The Taptic engine is driven by an IC that is identical to the speaker amp so it is possible that this circuit was accidentally damaged during the Tristar repair. I would reach out to your micro-soldering tech to have them take a closer look. If the damage was incidental, they should cover it under warranty.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 100
