주요 콘텐츠로 건너뛰기
The Dell Inspiron 910 Laptop was released in 2008 as part of the Dell Mini Series of small, portable laptops.
Which up-to-date OS will work decently on my Inspiron 910?
I’m getting a 64GB Mini-PCIe PATA SSD, and I want an up-to-date OS on it. Not only that, but I need one that runs decently and hopefully looks nice on it. I’m considering Windows 10, and absolutely not Windows 7 (since performance is apparently horrible on it). I’m also looking into running a unique distro of Linux too, and I’m unsure about Windows 8.1.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
I have a Mini 9 2GB ram, 64GB STEC SSD I have used it every day for at least 3 years, with Win 10 PRO 1809, its slow but it all works. I use a Netgear 5G WiFI dongle. I have used WIN TO USB 8.1, which is much faster than 10, and runtime USB Mint Cinnamon, and XUbuntu, which are faster than 8.1. The only thing it needs is the CMOS battery, which is not worth the effort or the $10.
댓글 달기
답변 10개
선택된 해법
i would go with ubuntu, specs are too low for anything higher than windows 7. if you manage to get at least 2 more Gigs of RAM (assuming you have the 2GB model) you could try windows 8.1 but the cpu worries me to be honest and Ubuntu is better than evern right now.
Good Luck
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Ubuntu is pretty general, and I mentioned running a UNIQUE version of Linux. I was considering Windows 10 because apparently, it runs way better than Windows 7 on old hardware.
댓글 달기
Try Lubuntu. Free. Very fast, intuitive, no bloat, supports all hardware without special drivers. Installs from a usb stick. Thousands of apps covering most of your needs (compatible office, Firefox, etc.) . Probably runs in 500k ram but I have more. 4 hours battery life with a good battery. The 910 is a fantastic design so well worth keeping it going!
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
That's what I put on my 910. I believe they stopped making the 32bit version though. I had put win 10 on mine a while back... it ran better than win 7 but it was way too slow and was a xxxx to get installed. Video: https://www.youtube.com/watch?v=BG-uHKI5...
댓글 달기
This might be a too late response, but I was searching for answer to the same question in the past few days, and after several trial-and-errors, I’ve finally settled down with CloudReady Home Edition (32 bit) for my Dell Mini 9 (Inspiron 910). It is essentially a Google Chrome/Chromium folk with minimum bloatware and runs sleekly on my 2GB RAM and 16 GB SSD.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Starting at the end of August 2019, the Home, Education, and Enterprise Editions of CloudReady will stop builds, releases, and updates for 32bit images. :'(
댓글 달기
I have recently (April 2019) upgraded a hardly-used Mini 9 that just needed a charger. It had the original 16GB PATA SSD , 1GB DDR2 RAM, Windows XP. I upgraded to 2GB RAM with which it loaded and ran W10 Home Ver 1511, and then upgraded through to 1803. Then it ran out of disk space on the last upgrade but I was able to get it to load and run 1809 with the aid of a USB to 2.5” SATA adapter and a 256GB HDD system disk salvaged from an ASUS EEE-PC 1015PX (32 bit W10 V 1809). W10 works OK but is UNUSABLY slow. On the other hand, the Mini 9 runs Ubuntu Mate 16.04 LTS and 18.04 LTS just fine, though it can only handle video at about 240p before it turns into a slideshow. Look at Geekbench 4 Browser results for “Inspiron 910 Atom N270” - the Atom N270 in the Minis is the lowest scorer in my personal collection of devices that run W10. Hope that helps.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
How's Wi-Fi? I've tried some distros that seem to not support the Wi-Fi card.
댓글 달기
Go to distrowatch and look for architecture i386 for linux.
use a usb dvd drive, to install the os.
the dell mini 9 aka 910 is a 32 bit system with 64 gb max hard drive and 2 gb max ram.
I use linux mint 16 and ubuntu 14!
ooh get ubcd on cd for stubborn os`s that don`t want to be removed from the harddrive!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have a Mini 9, that came with 1 GB RAM, 8 GB SSD & WIN XP.
Now, it has 2GB RAM, 64 GB SSD that has been running WIN 10 x32 for years.
Slow and steady, but does everything you need.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
What SSD are you using? Is this external? I have a Dell Mini 9 with only a 16GB SSD and Q4OS Linux works but to keep it updated I am going to have to get a bigger drive.
댓글 달기
Got the same Atom N270 on my good ol' Aspire One, pretty poor performance for today's standards even for light desktop use, nevertheless its strong points were remarkable at the time, netbooks equipped with this single-core Intel CPU made awesome low-cost and low-consumption machines to tinker with - with the advent of mini-itx boards, it wasn't rare to stumble upon cool projects such as DIY car-puters and so on. Sure, it was not suited for multitasking, but you would get a decent and compact starter PC or retro game emulation machine for games from the 80s-90s (up to 16-bit gen probably) for a reasonable price.
Personally I tried many different OSs (even an open source Amiga workbench clone!) among which Ubuntu, but now many 32-bit variants are being discontinued. I suggest you give Antix (Debian based GNU/Linux distro) a try, I have 19.3 on my netbook and it feels super fast, considering it runs on an impossibly slow internal flash drive.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Am running MXlinux 32bit….runs great.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Be sure to try PuppyLinux (BionicPup32). It is a tiny distribution, that uses very little system resources itself, so you have lots of overhead for programs. Have had it run YouTube smooth at 480p right out of the box on much weaker hardware than what is in the Mini 9.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
so im currently deling wiht this, ive had a mini 910 offand on for years, I came across one, and he ssd was toast, and I couldn't afford another, o so I sacrificed a USB port, desoldered and soldered in a small female half of a USB extension cable in ,and routed it to the wlan bay un used, i got a 32gb USB drive, and installed ubuntu from another USB drive, its maxed at 2gb ram, and i know it can only see 64 HDD, it ran great for a long time, and then got a replacement and kicked around in a closet for a while, it resurfaced, and my 2 year old son loves it, he's super advanced has a tablet, and was stoked when he saw it, like mine, my size mine, lol and we were doing the ABC on the kyb, and he was stoked, carrying it around and pretending to type like dad and mom doo, - this kids already riding a 2 wheeler without training wheels, rock climbing and doing things 4 yr olds do, speech and logic and memory, etc, i swear this kids gonna be riding a 50cc dirt bike and coding by the time he's 5 yr old, lol watch out world,
anyways, i wanted to run ubuntu and tried the new v 20, i found that it doesn't work for the 910 but requires the IoT version that now runs the atom N CPUs,
before the regular ubuntu 14 worked fine, but 20 does not,
- I'm downloading 20 IoT now, and ill see if it takes and runs any better, it is supposedly lighter and meant for smaller setups, so it may breathe some live in the 910 once more,
, idk i thought some of you would like my USB hack workaround and repurpose of the 910 minis, that initially was sold for ubuntu and is one the only systems that i know of that came OEM with ubuntu and was designed for it,
- I know this is another thread question, but does anyone know of any ubuntu coding games for kids, toddlers, boolean logic gates, and that kind of thing?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
(Q about coding games) The only one I know of is Scratch - https://scratch.mit.edu/scratch_1.4, I think you can find it in Software Center
댓글 달기
답변을 추가하세요
TheYootz Media Group 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 84
전체 시간: 5,683
