주요 콘텐츠로 건너뛰기
여러 모양, 크기 및 색상의 Android/안드로이드 핸드폰 수리 안내 및 분해 정보.
33751 질문 전체 보기
I did something to fix my phone
I found in the internet that after you dropped your phone into the water, you need to dry it off then bury it inside a container with an uncooked rice. Is it gonna work? What should I do if that’s not gonna work?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hello Ashley
You can not repair a terminal damaged by liquids without opening it and clean the plate completely with isopropyl alcohol + 90º.
Charging or turning it on will only damage the interior.
Repairing a wet terminal without opening it is like operating a patient with just caresses and good words.
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi @gachaz
for first, if your mobilephone is damaged by water, it will be damaged forever. Inside of mobilephone, there is some special protective layer, which protect your phone against corrosion caused chemical reaction between air and PCBA’s material. This protective layer can be removed by water and after the layer is removed, your mobilphobe - PCBA - will not be protected against corrosion. Also, the firts what you have to do after your mobilephone was in water, is remove battery, SIM, SD Card and protect your phone against shorts caused from battery to PCBA, but there are a lot of condenser, which are having charge, so you will be lucky, if the mobilephone will be fine, but not for a long time.
Anyway, if you want to dry your phone, you have to use special - silica gel - which having best absorption of water/humidity.
See attached images below.
Your mobilphone will be fine only for recover your necessary data - it will die anway.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ashley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 58
