주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Bottom pentalobe screw spinning in hole
Hi guys,
I replaced the screen on an iPhone SE I acquired cheap but am experiencing some strange behaviour with ghost touches and missed inputs. To fix this I will try cleaning the contacts and or trying another display but on trying to open the device one pentalobe screw comes out fine but the other just spins in the hole at the bottom of the device. There is another question on here describing similar behaviour on an iPhone 4 but my experience differs as I am using the official screwdriver from my ifixit kit and the handle of my screw driver has not come loose with the shaft and screw remaining stationary as was suggested on that post and the screw head is in perfect condition with no stripping as was also mentioned in the other post. The screw spins perfectly just with no backing off.
I’m baffled guys i have tried the rubber band method even though the screw is not stripped and different screw drivers any help would be greatly appreciated.
Thanks,
Callum
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Screws just spinning generally mean the metal posts have broken off the screen. Or back cover for your iPhone 4. Sometimes lifting up the bottom of the screen a tiny bit with prying allows you to remove the screw that just spins.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
If lifting up on the screen does not make the screw come out then I would see if you can just pop the screen out from the bottom. We run into this some times when we are doing repairs. It's also sometimes possible to get the screw to attach to the screwdriver it is's magnetized and pull it out.
댓글 달기
귀하의 답변을 추가하세요
Callum Cooper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 7
전체 시간: 252
