주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Flash ROM apparently dead.
Hi all. I am looking at buying an iPhone 6 plus privately. It was upgraded to iOS 12 at which point the seller is saying the flash ROM has died/crashed and the phone now won't boot fully into IOS. Questions are:
1) is this common?
2) is there a fix and if so, is it complicated.
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
yes there may be a fix... does the seller tell you it is jailbroken? does he get an error code? Sometimes stuck in boot loop is an easy fix, sometimes it's a brick. Ask for the error code and then we can give more accurate answer
댓글 달기
답변 1개
선택된 해법
Are you referring to an iPhone 6 Plus or an iPhone 6S Plus? Your question and product selection don’t match.
There is no Flash ROM in an iPhone. There is an EEPROM, and SDRAM and a NAND IC. If your seller can give you more precise information, then we can help you better. That said, none of these issues are trivial in nature and unless you have micro-soldering skills, I wouldn’t bother with this device. There are plenty of quality pre-owned devices out there, you don’t want to be saddled with a phone that has logic board issues such as this.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
iPhone 6s plus as per the thread title.
댓글 달기
답변을 추가하세요
Simon Palmer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 237
