Does this have an M.2 SSD expansion slot?
I’m considering adding an SSD as a new boot drive to make it faster and want to know if it has an extra slot, particularly for an m.2 drive.
좋은 질문 입니까?
좋은 질문 입니까?
Hi @iridi ,
It does not have a M.2 slot but according to the service manual it has a PCIe slot for either a half mini WAN card OR a mSATA SSD.
Go to p.63 in the service manual to view how to remove / replace the component.
The manual also mentions the following regarding the mSATA :
If the computer is equipped with both a hard disk drive and an mSATA solid-state drive, do not use the mSATA solid-state drive as a bootable device. The mSATA solid-state drive is designed and developed for “cache” function purpose only.
If the computer is shipped with both an mSATA solid-state drive and a hard disk drive, the mSATA solid-state drive is used for the “cache” function and to support the Intel® Rapid Start Technology. We recommend that users do not replace the mSATA solid-state drive by themselves. Otherwise, the “cache” function will not work and the Intel Rapid Start Technology cannot be used any more. Attention: Ensure that you partition the mSATA solid-state drive after installing it on the computer you are servicing. Otherwise, the mSATA solid-state drive will not function correctly. For instructions on how to partition an mSATA solid-state drive, go to http://www.lenovo.com/support/msata-fru.
해당 답변은 도움이 되었습니까?
Nope, only a 2.5” SATA drive slot for SSD or HDD that's 2.5” (laptop size).
You can use crucial website to easily check compatibility.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 1,972
