주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Battery stuck on 1% and restarts randomly, after screen replacement
After replacing the screen of my iPhone SE the phone is stuck at around 1% (highest I’ve seen it go is 5%). All I did is replace the screen and the only touching of the battery I did was to unplug it so I did fry the screen. I have already tried turning it off and on as well as unplugging and plugging back in the connector to no avail.
Any suggestions would help, also if you know how to fix the problem it would be greatly appreciated if you could what I’d need to do to fix the problem.
If you need to ask any questions ask away.
Thanks, Tom.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL2400, at the top-left of the connector. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Tom Thompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 99
