주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Chips missing above battery connector -do all of them need replacing?
Hi,
I recently recieved an iPhone 5S stuck in a boot loop, and I noticed some of the chips missing from above the battery connector (I’m guessing they where knocked-off in a prior attempt to replace battery).
The missing chips are: FL11, C279, C23, and C25.
I’ve looked at other similar questions on the forum and have determined that FL11 is essential and must be replaced, however are the remaining three neccessary to replace?
Thanks very much!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You are correct that FL11 is required for proper communication of the battery status to the CPU. The other capacitors are there to insure noisy signals are properly attenuated and in that respect, the device will work without them.
However, if you are charging for repairs, then IMHO you should be replacing all missing components. This is just my humble opinion and it is suitable for framing or wrapping fish (I’m dating myself here ;>).
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks for the advice. Time to source some parts!
댓글 달기
귀하의 답변을 추가하세요
Nathan Arnold 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 38
