주요 콘텐츠로 건너뛰기
A high-end PC workstation by HP, released in April of 2012.
4 질문 전체 보기
Fatal memory error 927
Hi,
My HP z820 has this problem: 927 Fatal Memory Error. memory error detected CPU1 DIMM slot 5 or 6. The system required rebooting by press F1 button,
Please can you give me any advice or instructions on how to solve this.
Regards,
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Same problem here , did u find any solution ?
댓글 달기
답변 1개
선택된 답변
ghazwan_khalaf  here is what HP has to say:
Message:
927—Fatal error on DIMM in slot CPU X DIMM Y
Cause:
Fatal multibit ECC error detected on the DIMM in the slot labeled CPU x DIMM y (where x is 0 or 1 and y is 1 - 6), as labeled on the system board.
SOLUTION:
Replace the DIMM in the identified slot.
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
ghazwan_khalaf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 88
전체 시간: 6,047
