주요 콘텐츠로 건너뛰기
Isuzu Motors Ltd./이스즈 자동차가 제조한 승용차 및 트럭 수리 안내서 및 지원
How to reset instrument cluster on 2010 isuzu dmax 4wd?
Currently none of the gauges work but the warning lights work. Is there a way to fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi,
Did you check the fuses in the instrument panel fuse box to see if they are OK, you didn’t say?
I don’t know your vehicle and couldn’t find a manual for your year model D-Max but found one for a 2012 -2015 D-Max which shows 2 fuses with “meter” designations.
Worth a look anyway to check if yours is the same or similar and if they’re both OK or not.
Here’s an image taken for the manual showing the 2 fuses.
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
fuses are good .. have to test another panel board to see if the stock is faulty. and found out it was. so we remove the stock board trying to repair it. hope reheating the circuit will do.
댓글 달기
답변을 추가하세요
Stephen Ramsamooj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 71
전체 시간: 6,890
