주요 콘텐츠로 건너뛰기
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 질문 전체 보기
Kenmore elite Oasis HT leaking
(I know, kind of an older model). It leaks underneath during cycle. It’s obviously happening during spin and I can see the actual holes where it is coming out but I don’t know what is causing it. Can anyone help?
The last one is from underneath and I can see the water is coming from the tiny holes at the middle of the “wagon wheel spokes”.
Update (03/24/2019)
Model # :11028092700
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 6개
Here’s pic if all info from a service receipt [image|1717260]
[image|1717260][image|1717264]
Great, thanks. Now lets see what we can find out specifically to your washer
Okay ty. So i have been researching and it sounds like I need the part number W10435302kit to replace bearings and drum seal. We really hadn’t questioned the noise level during spin, since our washer is pretty old but the noise and the holding water in the outer tub sounds like what others described. What do you think?
.... my problem also though, is I’ve got it all taken apart down to the drum and I can’t get it out… It won’t budge. Do you think rust? We have pretty hard well water and there’s a lot of lime buildup everywhere too
댓글 1개 더보기
댓글 달기
답변 1개
가장 유용한 답변
@gainey that looks like a leaking tub seal. The main tub seal is located between the transmission and the outer tub. there is always the possibility of a bad hose or a split tub. you will have to further disassemble your washer to make a definite diagnosis. Let us know your washer exact model number so we can possibly help you out further.
해당 답변은 도움이 되었습니까?
점수 1
댓글 6개:
Okay ty. Any idea where the model #is?
Ive gotten the water drained from outer tub now
Okay model # is 110.2808, 2809
Anyone there?
Kenmore Washing Machine 110.28092700
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Toni 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 276
