주요 콘텐츠로 건너뛰기
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
170 질문 전체 보기
Which laser do I need? (Rev.A Samsung SDG-605)
I got this Xbox along with a 2nd one as a lot yesterday. The first one worked but this 2nd one has given me a lot of grief with the laser. I have tried to clean it and then adjust the trimpot on the laser and it still does not work. I have come to the conclusion the laser just can’t be saved.
In addition, I maxed out the trimpot at 3.11 before you can’t adjust it further without getting into damaging levels of power.
Since I’m at a dead end with this Xbox, I need to know which laser I need based on the model provided in the title. I don’t think it matters if I mix up drives in the Xbox as the drives aren’t paired (that or it doesn’t matter as of 2010; AKA Xbox Live V1 shutdown) but I’m not sure - I know my 360 is paired, but I don’t know about the original Xbox. I see more Thompson drives then Samsung and it’s known the Thompson drives have more problems - I’d like to stay with Samsung if at all possible.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
SOH-D12 should fit yours but we would need to see what yours looks like. SOH-D12 and SOH-D16 covers most of the Samsung’s
Update (03/24/2019)
Not sure what you are referring to with the 1.4 etc.
Anyhow, if you check your pictures you will notice that your laser is labeled. Yours is a SOH-DX1 and available at places like this and many others.
해당 답변은 도움이 되었습니까?
점수 2
댓글 14개:
Pictures are added. I've tried to adjust the laser and it still doesn't work at 1.4 ohms. I've been trying to get it working and it still hasn't work at 1.2 ohms. If I can't get it going at 1.1 ohms, I'd rather condemn the laser then risk it because the limit is 1 ohm.
I didn't add photos because I was under the assumption ALL of them use the same part rather than 2 possibilities since these are custom console drives.
will the laser lens from a xbox360 work?
@bulkchart32 Different drive models - no. The Samsung and Thompson drives use different lasers, so you need to know which one you have. The Thompson is known to fail, so if you have that look for the SDG-605 drive if you can.
Both of mine are Samsungs.
i have the same exact drive as u, nick. where'd u find a laser from?
@bulkchart32 eBay. Search S0H-DX1 and you'll hopefully find one - it can be harder to find. Click me for a laser. It comes from China but it's SpeedPAK - Customs is the issue in shipping delays for those of us in the States. However, we have a high informal entry limit, so there shouldn't be any duty involved.
Mine cleared Customs same day I'm just waiting for mine to arrive so I can salvage the other one. I only got to it recently since it's so hard to find one.
댓글 9개 더보기
댓글 달기
귀하의 답변을 추가하세요
Nick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 101
전체 시간: 6,135
