주요 콘텐츠로 건너뛰기
스크린 크기 5.3” 스크린 해상도 1280x720 Pixels 배터리 용량 2,700 mAh 카메라 해상도13MP 프로세서 Qualcomm Snapdragon™ MSM8917 1.4GHz Quad-Core 메모리 2GB RAM 저장 용량 32GB ROM (최대 사용 가능 23.21GB) 통신사 T-Mobile 또는 MetroPCS 다른 기능 Android 7 (Nougat) 운영 체제, 5MP 전면 카메라와 제스처 샷 & 셀피 빛, 4G LTE 연결성, 모바일 핫스팟, Rear Key/리어 키 지문 센서. 모델 TP260 및 MP260
31 질문 전체 보기
Why is my phone keeping ringing a weird drum beat sound?
My phone has been acting up lately with this unknown weird sound lately. It sounds like a jazz type of beat and it just won't stop, no matter what I do with it. I restarted my phone, I had to delete other apps that was affected by the sound, and tried everything to make this stop, but it didn't.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
just turn off notifications… this will stop the noise…then you can turn on each app notification that you want …wait to see if its the issue…and continue one at a time…no need to delete them
댓글 달기
답변 2개
선택된 답변
Hi @markerz2020 ,
Try starting the phone in safe mode to check if it works OK or not.
If it works OK then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
You need to uninstall each downloaded app, one by one, and test the phone between each uninstall. When it works OK the last downloaded app that you uninstalled was the cause of the problem
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Try resetting you phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Marcos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 34
전체 시간: 1,278
