Samsung tab pro sm-t525
Hello,
i have a samsung tab pro sm-t525.
device charge bad so i replace 2x the charging port and the batterij but still same problem.
device stops charging after 2-3 min.
좋은 질문 입니까?
Hello,
좋은 질문 입니까?
vdb consulting since you already changed the battery and the USB connector (hopefully it is a good repair and the parts are functioning normally) you want to go ahead and check the charging circuitry according to the schematic
해당 답변은 도움이 되었습니까?
Then it’s probably a battery issue here is the replacement.Samsung Galaxy Tab Pro 10.1 Battery Replacement
해당 답변은 도움이 되었습니까?
No, we change the battery also, no result..
Stops everytime with charging
Did you get them from a good place like ifixit?
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 271
