Vintage component Identification help needed.
Hi all, I attached a picture of a component that I am having trouble identifying. The text reads 38132 OR 38|32 RCA CNK IC, also I am on the hunt for Sherwood S-8500 schematics!
좋은 질문 입니까?
좋은 질문 입니까?
That is reference designator Q308 which is a RCA NPN transistor. For your S-8500 transistor Q208 and Q308 are identical. The original transistor was either a RCA 38132 or a Fairchild 40361F
Type Designator: 40361
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 1 W
Maximum Collector-Base Voltage |Vcb|: 70 V
Maximum Emitter-Base Voltage |Veb|: 4 V
Maximum Collector Current |Ic max|: 0.7 A
Max. Operating Junction Temperature (Tj): 200 °C
Transition Frequency (ft): 50 MHz
Forward Current Transfer Ratio (hFE), MIN: 75
Noise Figure, dB: -
Package: TO5
These documents should be of interest to you SchematicSherwood-S-8500-Partslist.pdf
해당 답변은 도움이 되었습니까?
YeSss!! thank you so much OldTurkey! If you are in located in the states and their is a concert you want to attend (within reason) let me know and I'll try to hook you up with a pair of tickets. I am a promoter/talent buyer for a performing arts center in MA and can sometimes get tickets for shows in the US. I owe you one!
Aaron, OldTurkey lives in TX, checkout his info card for email.
Check out this vid If You Have a Repair Question These Guys Have The Answer!
Aaron that is awesome! Great that I could be of assistance ;-)
why can't we upvote comments yet?? great job OT03
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 194
댓글 8개
looking at the other side how many connections does it have, two or three?
Dan 의
it has three pins
Aaron 의
So you have a transistor which could be a geranium or silicon configured as either a NPN or PNP.
Dan 의
Right, I am hoping to find specs as I need to find a replacement.
Aaron 의
Here's one possible source for the Schematics SHERWOOD SCHEMATIC: MODEL S-8500 FM STEREO RECEIVER
Thats the best I can do. Sorry
Dan 의
댓글 3개 더보기
