주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 제작한 4세대 무선 키보드입니다. 2015년 10월에 출시되었습니다. 모델 A1644.
Issue with one key
So im getting this weird issue, on my magic keyboard. The down arrow does’t work by itself. no water damage
but if i press shift and down arrow it will scroll down
also if i press command and down arrow it will also scroll down
but if i press the down arrow by itself it wont do anything.
what have i done so far
  • cleaned the weird silicone dome inside the key with isopropyl alcohol
  • factory reset the keyboard
  • let it discharge and recharge it
nothing helped so far
anyone else had encountered this error?
Thanks in advance
UPDATE:
I include a picture of the issue
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The switches contact blister has failed. The keyboard is not really repairable.
Update (03/29/2019)
Yes, this can be confusing! Why does pressing two keys make it work!
This gets into the mechanics on how a keyboard works. Simply put, its like a spreadsheet a group of columns and rows, in this case the down key has failed so when the neighboring key (electrically) is also pressed the signal gets driven to the decoder logic within the keyboard and it accepts it as the key you wanted.
Often times a liquid spill is the cause of this type of problem.
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
But how it works when pressing shift+down and command+down. I can confirm this on the on-screen keyboard key pressed, but only in combination with other key.
The way I can make the down key work is by pressing F5+Arrow Down, since F5 doesn't do anything will not affect in the response of going down one cell, on numbers app, for example
Thanks for the quick reply. Can it get fixed?
Sorry, this keyboard is just not repairable! Review the teardown Magic Keyboard Teardown
Thanks Dan, well this is just great, what an expensive PoS...
I personally prefer the wired keyboard. Here's a refurbished unit Apple Aluminum Wired Keyboard MB110LL/A (Refurbished) Still the best Apple keyboard!
댓글 달기
답변을 추가하세요
Robert G 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 19
전체 시간: 1,104
