주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My TV won't turn on
It clicks like it's going to turn on then it turns right back off
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
REF: https://data2.manualslib.com/pdf7/148/14...
The above link is the service manual for your TV. On page 1, the very first paragraph, highlighted in yellow, it describes a scenario where the power LED turns on for 10-20 seconds, then turns off for 1-2 seconds and keeps repeating. If your light is coming on and off repeatedly, then it is most likely IC5750A. Use page 1, to determine the correct part number. Though, I would try uplugging the TV for 30-60 minutes and plugging back in, to see if the TV would reset before looking at any particular part replacement.
However, if the light is not repeating, go to page 5, of the service manual, and follow the steps for checking the power failure circuit. Also, look at page 33, for the NO POWER troubleshooting flowchart.
From personal experience, a bad electrolytic capacitor in the power board is the typical culprit. Just look for burned capacitors. Here is an example of what to look for: http://www.yggenyk.dk/wiki/Burned_and_Le...
WARNING: The capacitors on TVs can hold very dangerous charges for long periods of time, and will need to be discharged before working on them. If you don’t know exactly what you are doing, hire a professional.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Tamika Kennedy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 938
