주요 콘텐츠로 건너뛰기
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
1209 질문 전체 보기
troybilt pony starts for a few seconds then stops
I have a troybilt pony that starts for a few seconds then stops. I have cleaned the carburetor, changed the air filter, spark plug and fuel. What else can I try?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
가장 유용한 답변
@esetch3
going by your short description, it sounds like it runs out of fuel. Check the float and needle valve on your carburetor. It will help if you can give us a model for your Pony and possibly an engine make/model. That way we can most likely help you a bit more. If in doubt you can always post some pictures of the carb etc. with your question 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I have Troybilt TB240 with an easy start Honda GVC 160. That shuts off after a few feet of mowing. Check gas lines and cleaned carburetor and new ethanol free gasoline.. Don’t what else to do.
댓글 달기
I had same problem with 1 yr old Troy Bilt and after following all online advice (cleaned carb, air filter, gas line, PURCHASED new carb, new gas) without success, sought out help from small engine expert at work - he fixed it and runs like a top. Turns out gas leaked into crankcase through carb into cylinder, as left in gas from last year so gas mixed with engine oil. After draining gas/oil from crankcase and refill oil it started right up and keeps on running. At the end of the season will either put in a valve in gas line and/or drain all gas from the tank after running with Stabil. My guy figures the float and valve get gummed up allowing the gas to drain through the carb to piston to crankcase. Good luck and if it works please reply.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you have tried all of those then maybe the spark plug wires or electrical systems are not making good contact. I would clean the contacts of the wires and if you have a multimeter use it to make sure the wires are working properly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What mine ended up being was where the gas comes out of the tank was plugged up with small pieces of grass. It was not allowing very much gas through. Glad I figured it out. I really need my mower.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Compresure is not enough it needs at lest
50 psi it’s probably 35
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Teresa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 12
7일 전: 63
30일 전: 205
전체 시간: 5,516
