battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
좋은 질문입니까?
좋은 질문입니까?
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
이 답변이 도움이 되었나요?
OK thank you
Hold finger on Questiomark for while..
still not working..... im getting mad
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
이 답변이 도움이 되었나요?
If you get anew battery note to remove the stick on the 4 battery connectors
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
지난 24시간: 6
지난 7일: 30
지난 30일: 155
전체 시간: 57,551
댓글 13개
My lg q6 alpha is showing the red question sign on the screen I don't what to do
careyellis18 의
What do I need too do if my phone want come on and only show a ? Mark
Samuel Houston 의
my lg is not turning on
Simon Weldemichael 의
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
mckinneymichael200 의
I have the same problem in my lg v10 question mark after connecting the charger
engineer malik 의
댓글 8개 더보기
