주요 콘텐츠로 건너뛰기
Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
77 질문 전체 보기
I am getting an error message from Amazon about not enough bandwith
I have a new smart tv, Vizio, and unable to play Amazon Prime videos  & tv shows.  The error message I get is not enough bandwidth, does this sound correct?  I am with Comcast.  Also, I can’t play Nextflix either, but when I talked to their customer service dept they said it is not a bandwidth issue, but has to do with the smart tvs and they have gotten many calls about it.  Not sure what to do. ???
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
@oldturkey03  Thank you for your help.  I ran the test and for downloads I got 38.2 Mbps and uploads 5.9 Mbps so I am not exactly sure how to translate this to what you wrote.  Also, while I am on Netflix they have a test you can run and according to their site, I pass the bandwidth issue.  The customer service rep at Netflix said they think it is something else because many people are calling in about the issues.  Therefore, I don’t know what to think at this time.
@sanddancer those are some good numbers and plenty to stream. this does not sound like it is an issue with your hard ware.
Okay... thanks. I will follow up with Amazon and Netflix.
댓글 달기
답변 1개
선택된 답변
@sanddancer it will depend on what kind of network connection are you using. I’d start by performing a simple bandwidth connection check. Something like this this test should work. You will need a minimum of 2.5 Mbps and 7.5 Mbps for HD and > 12 Mbps for streaming on multiple devices. Let us know what you find out.
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
귀하의 답변을 추가하세요
Anne Jordan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 8
전체 시간: 127
