주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Home button waterseal ripped off after screen replacement?
I did a screen replacement of my own and got kinda sloppy. Didn’t realize that there was a rubber around the home button and i accidentally ripped it off. Is there a way around this? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
It will work without it, but you break the water resistance in multiple areas. Don’t get the phone wet and it’ll be fine.
That said, I would replace the seal if at all possible or at least try and salvage the bad one. It’s still not going to seal right but 90% is still better then 0%.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Do you happen to know where a replacement seal can be found? Thanks.
You probably need to buy a display or an unpaired button (for the seal). I'd live with it since opening the phone compromises the water resistance anyway.
댓글 달기
Don’t bother. You don’t know if the screen itself is waterproof because it could be assembled from parts by some other factories and did not apply glue all around the bezel.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Usually doing a screen replacement involves in ripping the water seal of your phone. Breaking the seal where the home button is should be no big deal. Just make sure to always keep in mind that your phone is no longer splash proof
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mikel Pimentel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 637
