주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
My iPhone 5 only works properly when it’s charging
My iPhone 5 fell in water and I got it fixed. As of right now my phone screen is very unresponsive and rarely works and if it does work it is very frustrating to use. The only way it works properly is when it charging. I also have tried about a 100 times to restart my phone and even hard resetting it, and it hasn’t worked. What do I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You said when you plug in your phone The touch works right? In this case all you need to do is a battery replacement.
iPhone 5 Battery
If this wouldn’t be the issue it wouldn’t be worth it to fix the phone it would be cheaper to buy a new one.
iPhone 5 Battery 이미지
상품
iPhone 5 Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Too expensive. Any other way?
Change the battery to a phone damaged by liquids that has not been cleaned, it is not advice, it is silly. The first thing is to disconnect the phone and not turn it on until you clean it. If you have turned it on and used it, make a backup and recycle it correctly since it will not last long.
Read this please. You should know before advising @scottpine Electronics Water Damage
댓글 달기
You said your phone was dropped in water. How long from the time it was dropped to the time you had it fixed? Water damage repair has to be done a quickly as possible otherwise corrosion starts and can lead to all sorts of problems. Typically when we get devices that have been dropped in water we have to replace the screen. Did you get a new screen put on? That part that worries me a little is that it works fine when you have it plugged in. Batteries also tend to need to be replaced after being dropped in water. From past experience, Apple products do act funny when they have bad batteries. I would see if a local repair shop could test on of their batteries in your phone first to see if it fixes the problem. If it doesn’t then you likely have some other issues that need to be addressed.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
I brought it to get fixed about maybe 3-5 days after it fell into water.
I would see if a repair shop would try a battery for you first to see if this is the problem. I fear that with you waiting that long that something on the board might have gotten damaged. Best case is that a new battery fixes your problem.
Any other solution?
I unfortunately don't have any other ideas for you. If it was me, I would try a battery next. Just ask a local repair shop if they will test if for you for free. Connecting a new battery to the phone takes just a few minutes.
댓글 달기
귀하의 답변을 추가하세요
Gurleen Dhillon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 152
