주요 콘텐츠로 건너뛰기
Repair guides and support for your LG TV.
1341 질문 전체 보기
Left half of screen is darker than right side.
Good day. I have a LG model UA55F8000ATXXA 3d LED tv with the left half of the display a bit darker than the right half ( the split is exactly in the half with a straight edge…no fade ). This tv only lasted 2 years and is now standing for another 2 years. The unit was very expensive and i am just not happy with “ we do not support “ it anymore. I have taken it to two repair places, but they haven't even seen another one like mine, so no luck with fixing it. Can anyone please help me in the right direction by fixing it myself. See attached picture.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 6개
Don't know the answer, but its probably a backlight prob ;-)
I have the same problem… any solutions so far?
did you find a solution?
Hey Buddy , can you try to restore the factory settings of your TV if you can find any option to do it .
try also finding a firmware update for your TV.
otherwise then it must something to do with the Micro controller chips .
by the way did you contact the LG service Center?
Hi,
I have updated the firmware, as well as the factory reset. I have spoken to LG support services in South Africa, but they have only referred me to repair agents, which just said that it is not supported anymore. I just don't know why people have repair businesses, but aren't knowledgable on electronics...all they want to do is replace boards instead of testing and identifying the faulty component. The picture is still sharp but just darker.
Marco
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
I replaced a T can board and it works now. It cost me close to 40CAD on Aliexpress.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Ihor Lesiv are you the OP? Or was your TV the same model with the same issue? Glad you got it fixed instead of hitting it etc.
댓글 달기
You have a bad lean and either you can try applying some pressure to that side even hit it with your hands (one on the front and the other on the back at the same time) and then can check the fuses. But most of the time it is a bad connection like an original that has just become loose.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Camden brooks I do not think that hitting things or checking a fuse is going to fix this.
댓글 달기
@moxy not sure if you got your TV repaired within the last 3 years :-) Anyhow, this does not look like a backlight error at all. It is possible that this is a T-con board issue, a LVDS flat ribbon cable issue and even a panel (LCD driver board issue). I check with a new T-con board first. My concern on this is really that this is a panel issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Marco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 70
전체 시간: 6,472
