주요 콘텐츠로 건너뛰기
Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
72 질문 전체 보기
Replacement display assembly not working after assembly
So i bought a display assembly for a Huawei P9 and for some reason it doesnt work after i moved all parts (cameras, mainboard, etc.)from one assembly to the other.
The weird thing is that it works totally fine when plug in the display flex cable before i assemble anything.
Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
You probably bet a ribbon cable, so look out not to bend them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I don’t have a lot of familiarity with this model but check to make sure you aren’t putting pressure on any of the connectors or cables. Pinched cables can cause problems sometimes. Also, there might be something pressing on the screen causing it not to work. A bent frame can sometimes be the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Antonio Cappuzzo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 54
