주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1200 질문 전체 보기
Glitchy screen after screen repair
About a week ago I replaced an iPhone X screen. Everything was working fine after the replacement. Two days later the screen started to glitch and just go black for a split second and go about life… The problem is still there and I’m not sure why. Can it be the screen is faulty maybe???
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 6개
가장 유용한 답변
Where did you get the screen, the touch panels on the copy oled, HO3 and LCD versions of the iphone X are the cheaper kind (you can see the easy digitizer in sunlight) are not very good.
There was a known issue with the iphone X causing touch problems after repair and this IIRC was a software update.
Try reseating the connectors and see if there is any bits of crud in the connectors on the motherboard.
it could very well be just a bad screen
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I had the same problem, I sent the screen back and got a replacement. I haven’t had any graphical glitching with the new screen, so I would say it’s pretty safe to assume that the screen itself was faulty.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try By hard resetting your iPhone, you’ll force it to abruptly turn off and back on. Sometimes crashed software can cause screen glitches, so restarting your iPhone may fix the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same issues, and it frustrates me because it interrupts my delivery routes. I was told by an expert that it could be a defective screen (the cheap kind) or that I need to clean most parts with a brush and electrical cleaner, but I hope it's a screen because it will take less time to replace than taking all the other parts out to clean it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i got 2 screen iPhone x
from you i install first one not any issue ,but second one had flickering and turned iPhone to lock mode that said try to put screen pin 5 minutes later and so on....
i sent it back they gave me a new one but this one got the same problem..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sometimes this happened’s when the screws are to tight. Make sure thy aren’t to tight.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 2개:
how do you untighten them
@MaeTiny Lofton using the correct bit, twist slightly counter clockwise.
댓글 달기
귀하의 답변을 추가하세요
wm_alvarez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 13
7일 전: 94
30일 전: 401
전체 시간: 8,111
