iMac stuck in white screen
Hi, my iMac is stuck in a white screen when i turn it on. I already tried everything like shift, option + r and stuff like that. I don’t know what to do anymore
좋은 질문 입니까?
좋은 질문 입니까?
A white screen is usually indicative of a failed hard drive. It is not seeing a drive or a system. Try booting from an external USB source.
해당 답변은 도움이 되었습니까?
Do you know how I could do that? It's stuck on the white screen so I can't even access the option to actually boot from the USB.
When you reboot with the USB (with a system on it), hold down the option key to select the external drive.
Before you do anything to solve the Mac frozen screen, try an easy fix: check your peripherals. Try to disconnect all of them (printers, scanners, USB devices, etc.) with the exception of the keyboard and mouse.
If it fails and your MacBook won’t load, check out other possible ways to wake up your Mac.
1. Boot into safe mode
2. Reset PRAM/NVRAM
3. Use Disk Utility to verify or repair disks
4. Reinstall macOS
Hope this will be helpful.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 101
댓글 4개
Can you tell us which model you have. Review this listing EveryMac - iMac's listing
Dan 의
Hi Dan, I'm not really sure but I guess its an
iMac "Core i3" 3.06 21.5-Inch
Lucas Batista 의
OK, we're at least hitting the barn, lets try hitting the barn door ;-}
On the bottom of your stands foot you'll find the systems serial number plug it in here to see if we can get a more accurate here EveryMac - S/N Lookup. What did it tell you?
Dan 의
Hi Dan, sorry for taking so long to answer. The Imac model is
iMac "Core i5" 2.66 27-Inch (Late 2009) 2.66 GHz Core i5 (I5-750)
Lucas Batista 의
