주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ZenPad 3S 10은 ASUS가 2015년 10월에 출시한 ZenPad 라인의 9.7형 태블릿입니다. 모델명: P027.
Screen doesn't respond to touch
Hi there,
The touch screen was working as normal when I started using the tablet. Some minutes after I found out by chance that part of the screen was cracked.
A bit after, the upper half of the touch screen stopped working. I restarted the device and the upper half continued bot working so I restarted it again and the whole touch screen stopped responding.
So, after many restarts, the display works, and I can see the lock screen but it doesn't respond to touch. The volume up/down and the home button still work.
Thanks a lot for any help (and sorry for such a long description).
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
You could easily change the screen looking youtube videos (if you have some experience) and buying on ebay 50€ more or less the screen.
You should be very careful replacing the screen, you must put glue to stick it very well, like it was, if not you could break it again. It’s very delicate.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aléxandros Vlachos Carola 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 373
