주요 콘텐츠로 건너뛰기
2014년 10월 16일에 발표하였으며, 모델 번호 A1347 및 EMC 2840로 식별할 수 있습니다.
Question about logic board replacement
I was wondering if there would be any issues replacing my logic board in my late 2014 Mac mini, I use it for a lot of server items and its getting rather run down. It currently has the i5 @ 2.6ghz and 8gb of ram. It isn’t to expensive to buy an upgraded board with more ram (the i7 @ 3.0 ghz w/ 16gb of ram). The major issue I see come into play is if apple changed heat syncs or power supplies depending on which board was place in the computer to begin with.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I would suggest going with an SSD to give it a really big speed boast:
[링크된 제품이 누락 또는 비활성화 됨: IF107-142]
Mac mini Late 2014 Hard Drive Replacement
Mac mini Late 2014 SSD Replacement
UPDATE 5/30/19
I got one of these in for a hard drive upgrade yesterday. It seems that if the machine did not ship with a factory SSD installed, it may not even have the slot in it to put an SSD stick in.
Mac mini Late 2014 SSD 이미지
안내서
난이도:
조정
15 minutes
Mac mini Late 2014 Hard Drive 이미지
안내서
난이도:
조정
30 minutes - 2 hours
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
I was thinking about that but didn't know if it would be more worth it to look at a logic board replacement. If I did do an ssd it would have to be a 1TB any recommendations on that front?
Your machine will take both an SSD blade and/or a standard 6.0 GBs drives. What is your current configuration? The blade is going to be much more expensive than just a standard drive. Although the SSD blade is very easy to install, the standard SSD 2.5" drive is difficult.
Here are the options from OWC but we may also want to look at a Samsung EVO 860
https://www.googleadservices.com/pagead/...
https://eshop.macsales.com/upgrades/mac-...
Well as far as I know I only have 1 drive in the Mac, and its a 1tb drive.
@samurai_jack - I would add in the PCIe blade SSD as its a lot less work and in the long haul will offer the most bang (much better than swapping out the logic bd to get a faster CPU). Whether you go with OWC or Transcend SSD's or Apple's Samsung SSD's is just a matter of cost and availability. Do keep in mind you don't need a massive SSD to gain performance! A 128 or 256 GB maybe all you need here.
Here's a good review of the different Apple SSD's: The Ultimate Guide to Apple’s Proprietary SSDs
댓글 달기
답변을 추가하세요
Ben 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 443
