주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2188 질문 전체 보기
Why is there no action from taptic engine after audio ic replacement?
So i recieved an iphone 7 that had the audio ic replaced. The customer said that it doesnt vibrate and people can not hear them as well as putting it on speaker changes nothing and sound still comes through the top speaker. I tested everything and they are correct about all of the issues. Also they stated that it will restart randomly for no reason. If any one could help me narrow down what's wrong with this board I would greatly appreciate it. Thank you all in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The first thing to suspect is that the Audio IC repair didn’t go smoothly. If the “new” symptoms roughly correspond to the Audio IC repair, then I would inspect the workmanship and use that as a clue.
Assuming the Audio IC was properly replaced (with jumper on C12 at least) and there no obvious signs of missing, dislodged or bridged components, then I would start probing the the ARC circuit (taptic engine) and work my way from there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
in my experience, if this occurs - reballing homer would help.
댓글 달기
귀하의 답변을 추가하세요
Blaked89 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 478
