Is it ok to replace the screen
I dropped my phone and now it has a slight bend. Should I get it fixed?
좋은 질문입니까?
좋은 질문입니까?
Since the iPhone logic board inside is firmed to the housing with screws, there might be consistent pressure on it that could lead to troubles sooner or later. Screen too may be working bad and create issues. It would be a good idea before replacing screen to straighten the housing or replace that part too after removing the logic board.
Here’s the guide to help you do the job:
이 답변이 도움이 되었나요?
The bend is only on the volume rocker side And the replacement is Coming in a week. Is it ok to wait or should I fix it as soon a possible?
@shaven_gren It shouldn't be a problem, the left half of the housing is mainly occupied by the battery and smaller components. Unless you feel unusual constant heating coming from the phone it won't be a problem to use it as it is for some time.
Alright thanks
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 124
댓글 1개
Why not sure you can fix it .There is small bend no problem.
Akash 의
