주요 콘텐츠로 건너뛰기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 질문 전체 보기
Do I need more adhesive after replacing the batttery
Since the battery replacement requires taking out the motherboard, does the motherboard need more adhesive to reattach or does it just stick to the old adhesive ? Just to clarify, I mean adhesive for the motherboard and not for the front panel, But does the iPad Air 2 adhesive strips come with motherboard adhesive? Like these btw iPad Air 2 Wi-Fi Adhesive Strips
iPad Air 2 Wi-Fi Adhesive Strips 이미지
상품
$6.99
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
The adhesive under the logic board is usually good when the board is re-installed, unless you really mangled it up a lot during removal. As for the screen adhesive, the one linked isn’t really that good. You should buy the Tesa Tape , also sold here. For roughly the same price, you’ll get more adhesive which can be used for other projects and the Tesa Tape is pretty much the best you can buy currently.
You may also want to check out a previous answer of mine regarding some iPad re-assembly best practices (After doing my repairs (battery and screen) I have problems).
Tesa 61395 Tape 이미지
상품
Tesa 61395 Tape
$5.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thank you so much!
댓글 달기
You should use new adhesive because especially on iPhone home buttons, when the adhesive meets a heat gun, it loosens and looses it’s use. You should definitely replace the adhesive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
So in short term, seeing you replaced the battery, I’d say if you used around 3 strips evenly spread along the battery it should be fine and stay held in, if you used less or prefer adding more to make sure it stays there feel free :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ok, I think you may have misunderstood, Replacing the battery requires taking the motherboard out, Where do I get more adhesive so I can put the motherboard back? Or can I just place it back there?
댓글 달기
귀하의 답변을 추가하세요
lrh33702 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 625
