주요 콘텐츠로 건너뛰기
GPD XD는 중국 회사 GamePad Digital에서 2015년 하반기에 출시한 안드로이드-기반 휴대용 게임기입니다. 정전식 터치-스크린 한 개가 있으며 에뮬레이터 및 기타 기본 안드로이드 소프트웨어 실행에 최적화되어 있습니다.
Headphone icon will not go away
I’ve had no issues with my GPD XD plus since I got it but recently after using some TRRS earbuds for about a week now, The headphoner icon will not go away when the headphones are unplugged. The only way to get the sound to play out of the speakers again is to manually flick the setting via a third party app such as https://play.google.com/store/apps/detai.... Headphones and speakers work when manually toggled but the jack detection itself seems broken. I’ve tried cleaning it, Tried plugging and unplugging the jack, Even tried a factory reset but the jack icon is still there.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
You probably have the wrong firmware on it. The headphone jack was replaced on the model and they reversed the polarities of the jack. As a result they had to add a second firmware that works for the new switch. Search the GPD site and get the other version of the firmware you have now. You should also consider getting CleanRom. This is a custom firmware for the XD+. Once installed the fix is just a toggle. Once toggled you are done.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vyvyn CruxButt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 287
