주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
How do I recover lost data without the help of backups
Due to having difficulties logging into Flickr app i was had to erase my device however I forgot to back it up to iCloud as it was going to be erased, I was hoping I’d recover the data if I restored from iCloud however I was unable to. If there are any third party apps that can help with this should I try it out to see if I’d recover the data from the 10th April to the morning of 17th April
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If you erased the device, there is ZERO chance of recovering any data.
There will be spammers recommending data recovery software on this post, do not believe them, none will work.
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
Hey Tom, My buddy down by the docks has a sweet deal I give him 100 bucks and he keeps it!
Sadly, Tom is correct once you've deleted your stuff off of a flash drive within your iPhone or iPad there is no means to restore it.
Unlike a spinning HDD which marks the file blocks free but not altered the flash or SSD (which is just another kind of flash) resets the cells completely zeroing them.
댓글 달기
The only way to recover lost data without the help of backups is using iOS Data Recovery. But if the lost data were overwritten, it’s impossible to recover them back. Please remember that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Stinger Solar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 70
