주요 콘텐츠로 건너뛰기
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
30 질문 전체 보기
One of my propeller (motor) is running slower than the others.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개:
Is there anything clogging the motor? We need mkre detail.
댓글 달기
답변 1개
Its possible fibers from carpet or clothing or hair fibers are wound between prop and motor. See instuctions to remove prop then debris can be easily removed from motor shaft. Do not press prop onto shaft to tightly. If this doesnt work motor might be worn or shot.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jean-Rene 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 116
