Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Its possible fibers from carpet or clothing or hair fibers are wound between prop and motor. See instuctions to remove prop then debris can be easily removed from motor shaft. Do not press prop onto shaft to tightly. If this doesnt work motor might be worn or shot.
Is there anything clogging the motor? We need mkre detail.
Jessica Parnelli Fawkes 의
