주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
PS4 Model CUH-1216B only has 2 screws, how do I open it
Hello, my PS4 Model CUH-1216B only has 2 screws on the back. Can you please explain how to open it. Since a few days it won’t start up again. Starting it, I only get a screen saying “connect the dualshock 4 with a USB-cable and next press the PS-key”, which doesn’t do anything. I got it once in safe mode and tried to reinstall everything, but then it crashed again and now I am stuck! Does anyone has an idea about what could be causing this? Thanks for your support.
Bob
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If you have already exhausted all the options in safe mode with the full PS4 initialization firmware file downloaded into the USB then it’s going to be a bad hard drive.
Software update can fail with error code if the blu-ray drive is not working. As long as you can eject and insert discs into the PS4 the blu-ray drive should still be good.
PlayStation 4 Hard Drive Replacement
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Press and hold the power button until you hear two beeps: one when you first press and another seven seconds later.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i can't click on the other options except for number 7 , what should i do ?
댓글 달기
귀하의 답변을 추가하세요
Bisshop Jyr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 1,447
