주요 콘텐츠로 건너뛰기
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
197 질문 전체 보기
There are Dark shadows on my LED TV screen
My samsung LED tv has dark shadows which appear all the time . any help will be appreciated
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
3 Comments
I also have this problem, Samsung don't want to know. They just say take it to my local service centre who are quoting £500.
@dean.barb925 did you want more info on this or are you okay with what Samsung told you? If so post a new question https://www.ifixit.com/Answers/Ask and add a couple of good pictures to your Question so we can see what your screen displays. 기존 질문에 이미지 추가하기
I have this problem, un58j5190 dark spots replaced power supply and worked fine replace power supply again this year still have dark spots pics are in the answer section by accident
댓글 달기
답변 3개
가장 유용한 답변
bakhtiyar.badar  that will depend on what these dark spots look like. It is possible that this is a bad backlight array, LED covers that have come off or a bad signal etc.. Remove the TV from power by unplugging the TV. Remove all video inputs. Hold down the power button for 30-60 seconds. After that connect the power to an outlet and use one local video source(i.e. DVD/BR player) and try to turn your TV on. Let us know what you get. You can always post some images of what your TV shows with your question. That way we can see what you see. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
more than likely the LCD panel is going bad. I came across one tv the a ribbon cable wasn't in all the way but there was a dark part of the tv about inches going top to bottom. Pinch the bezel a few times around where the dark spots are on the top or bottom. if they move then you have a loose connection..if they don't move and they are getting bigger it's a bad panel.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
If thats the case a loose connections how to fix it...thank u
댓글 달기
I did a factory reset. That got rid of my shadows on my Samsung tv . It shouldn’t be happening on a 1 year old tv!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How did you reset.
댓글 달기
귀하의 답변을 추가하세요
bakhtiyar.badar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 173
30일 전: 706
전체 시간: 55,602
