주요 콘텐츠로 건너뛰기
Repair for different sorts of record players, for recreation and music production.
109 질문 전체 보기
Does anyone have the service manual for the Numark TTXUSB?
I want to repair the motor of this turntable. When being cold it stops turning and sometimes even turns backwards, which gets better after you turned it with your hand a bit. So this sounds like capacitors having got old. Then I could also replace the the 2SB1340 and 2SD1889 transistors. Someone already did some soldering on the motor and added a foil capacitor to stabilize the motors Vin I guess, although its power supply provides a stable voltage. Would like to know what is still original here. Does anyone have experience with this turntable?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hello coldspark, i am Eduardo From Brasil and i can help you .
if some 2sb/2sd transistor was problem you need to change the smd mosfet drivers too. its 7002 transistor. BTW, if possivel, can you tell me the value of r55 ?
댓글 달기
답변 2개
선택된 답변
Hi
Not sure if this is the one you’re looking for as it doesn’t show the same transistors that you mentioned, but here’s a link to the NUMARK TTX VARIABLE TORQUE USB-DJ DIRECT DRIVE TURNTABLE circuit diagram, which may be of some help.
To download the file, pass the “I am not a robot test” below the Document Preview box and then when the sentence below the Document preview box changes from This file is downloadable free of charge (5/day): ...processing... to This file is downloadable free of charge (5/day): Download, click on Download, as this is the link.
Be patient as it takes a little while to find the file.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you! It looks very similar, but the parts names don't comply witht he ones on my device. Must be an earlier version, I guess. It's a start though!
댓글 달기
hello coldspark. If some 2sb/2sd transistor have problema, yoy need to change the smd modfet driver too.
Its 7002 smd mosfet.
BTW, can you tell me the value of R55 ?
regards
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
coldspark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 649
