주요 콘텐츠로 건너뛰기
가정용 및 차량용 오디오부터 계산기에 이르기까지 광범위한 전자 기구 수리 안내서.
26450 질문 전체 보기
PS4 HDMI port Not working.
Hi guys! Sorry for my bad english but im italian.
Ok so basically my ps4 took a 50 cm fall (really not that high)
And my hdmi stopped working for some reason, here is the photo of the port,
If there is anyway i can fix it without spending money it would be a pleasure.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
If it is less than a year it should be covered by warranty. If so contact Sony and tell them it stopped working. You most likely have damaged your HDMI connector but that could be put down to wear rather than impact as long as there is no visible damage to the case.
It may come back to life if you boot into safe mode and perform some system maintenance, maybe the system needs restored, rebuilt etc but I doubt it. Sony should be mice to you if it is in warranty still.
Check out these tips and see if they work.
https://www.partitionwizard.com/partitio...
https://ps4.wonderhowto.com/how-to/ps4-w...
https://www.ubreakifix.com/blog/fix-hdmi...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks for the reply, the ps4 is already out of warranty..
So, should i order a new hdmi port or this one is fine?
If the port is fine i think im gonna let someone that’s capable of to weld the hdmi port back to the mainboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
If HDMI port is pushed in, pins missing or damaged in any sort of way the port will need to be replaced. I would leave it to a reputable console repair shop to get it fixed.
댓글 달기
귀하의 답변을 추가하세요
mark89 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 934
