주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tefal Actifry - 대류식 조리기. 2006년에 처음 출시된 이 혁신적이고 다재다능한 튀김기는 다양한 음식을 경제적으로 조리할 수 있게 해주며, 다른 튀김기보다 더 안전하고 세척이 간편합니다.
Actifry tefal error 6
I get error 6 after few minutes.
Update (01/10/21)
The problem was on the electric circuit .
I have replaced the capacitors and the problem has been resolved!!!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 7개
how to repair E5,E6 on fryer tefal
의
Check the HZ may be defrance then specific of machine 50 or 60
의
My actifryer squashes all the food up what would the problem be
의
Please can you advise how to change the capacitors as ours started throwing the err6 fault code today but after 6 or 7 times of it doing it every minute or so it stopped and worked fine again so i imagine its on its last legs or overheating maybe
의
Could you advise where you got the capacitors and how much they cost please
Thanks regards Martyn
의
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
There are two capacitors. Change both of them.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Can u put pictures please
의
Where are they..? And what are they?
의
@Adrian Martin Take a look at the link in the second comment here by Eric B; there's a video and picture and places to buy the parts. It's in French, but that's what Google Translate is for.
의
I have got the same error. But the Black Actifry (model serie:025) does not have any capacitors, I discover... But I did get a third capacitor from the supplier, for free ;-)
의
댓글 달기
I have replaced both the motor and thermostat and that did not help. I did not have the tool to check circut board but visually all looked fine. At least now after 10 times of disaassembky I know how to do it. I will check the capacitors again.
The official info about contacting electric supply company is absolutely out of the question. I have tried different networks and sockets.
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
@Carlos Garcia quick question. do you have the error 6 on the actifry? Error 6 appears to be related to overheating of the 330nF capacitors on the circuit board. If you have this error post a couple of pictures of your circuit board so we can check things out.
의
Do you mean rhe gray capacitors
의
I have model IH7000 and it gave the same error... now it is OK
의
I am happy that I found a way to change the 334k capacitor & 100uf/35 capacitor error e6
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Dimitris Louvaris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 106
전체 시간: 29,762
