Actifry tefal error 6
I get error 6 after few minutes.
Update (01/10/21)
The problem was on the electric circuit .
I have replaced the capacitors and the problem has been resolved!!!!
좋은 질문 입니까?
좋은 질문 입니까?
There are two capacitors. Change both of them.
해당 답변은 도움이 되었습니까?
Can u put pictures please
There are a couple pictures here :
Where are they..? And what are they?
@Adrian Martin Take a look at the link in the second comment here by Eric B; there's a video and picture and places to buy the parts. It's in French, but that's what Google Translate is for.
I have replaced both the motor and thermostat and that did not help. I did not have the tool to check circut board but visually all looked fine. At least now after 10 times of disaassembky I know how to do it. I will check the capacitors again.
The official info about contacting electric supply company is absolutely out of the question. I have tried different networks and sockets.
해당 답변은 도움이 되었습니까?
So how it went? @rogerino
@Carlos Garcia quick question. do you have the error 6 on the actifry? Error 6 appears to be related to overheating of the 330nF capacitors on the circuit board. If you have this error post a couple of pictures of your circuit board so we can check things out.
Do you mean rhe gray capacitors
I have model IH7000 and it gave the same error... now it is OK
I am happy that I found a way to change the 334k capacitor & 100uf/35 capacitor error e6
24 시간 전: 8
7일 전: 78
30일 전: 335
전체 시간: 23,519
댓글 7개
how to repair E5,E6 on fryer tefal
baodo1973 의
Check the HZ may be defrance then specific of machine 50 or 60
Medhat Ali 의
My actifryer squashes all the food up what would the problem be
Anne lennon 의
Please can you advise how to change the capacitors as ours started throwing the err6 fault code today but after 6 or 7 times of it doing it every minute or so it stopped and worked fine again so i imagine its on its last legs or overheating maybe
Martyn Couper 40 의
Could you advise where you got the capacitors and how much they cost please
Thanks regards Martyn
Martyn Couper 40 의
댓글 2개 더보기
