주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Can I replace my charging port since it is not charging now?
I have an iPhone 7 plus that does not charge. I faced this problem a couple of months back too. I went and had it repaired in a repair shop and they told something that i could not understand. They also said that my phone damaged a couple of their flex too. I donot know what they were talking about and other thing is that the phone would charge if the lightning connector was connected on one side only. Meaning that the other side of the lightning connector wouldnot charge my phone. It worked on both sides till now though so i was hoping if replacing the charging port could solve my problem. HELP!!!!!!!!!!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
It’s unfortunate that you don’t remember or understood what the shop told you because it was certainly important. If you feel like you are being bamboozled, ask them to explain it again…it’s usually important.
Yes, you can replace the charge port but based on the history of the device and the symptoms it exhibits, I would suspect something may be wrong with the charge circuit on the logic board. Of course, the first step in diagnosing this correctly is to try a replacement charge port. If you do it yourself, you will have to buy the part upfront. Another option is to find a reputable shop that does micro-soldering as they will be able to dig a little deeper.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
yes you can. iPhone 7 Plus Lightning Connector Assembly Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Arun Rai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 81
