Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
좋은 질문 입니까?
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
해당 답변은 도움이 되었습니까?
thanks for answering
Please look at this question: What are Professionals Using for Screen Cleaning
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 459
댓글 5개
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
mayer 의
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
Amr Ateef 의
If its pure, then you should use it. My answer is YES!
Kon Dev 의
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
John Potter 의
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
Amr Ateef 의
